190XT Powerdirector Problems
dhs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhs Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Powerdirector Problems
    Posted: 08 Oct 2010 at 6:31pm
When I turn the steering all the way to the left or right on my 190XT the tractor will stop just as if you put the clutch in. As soon as you turn the steering back the opposite way the tractor takes off again. It does this in both the low and high side. Other than when turned sharp the tractor pulls good with no slippage. Is the powerdirector on the same circuit as the power steering and if so is there a priority valve that could be giving me problems? I am wondering if the oil supply to the powerdirector is being interrupted.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2010 at 9:15pm
The power director is on the same circuit as the steering. If you turn to the limits, there is not enough pressure to keep the clutch engaged.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2010 at 7:53am
Flowdivider in rear of pump is stuck.      MACK
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 11 Oct 2010 at 4:41am
Check you're oil level under the operators platform. You have two filling holes where a dipstick is.
It's right like Joe say's, the powersteering and PD are on 1 circuit. Also the hitch is connected to this.
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
dhs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhs Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2010 at 6:35pm
You hit the nail on the head Mack. I pulled the spool out of the bore, cleaned things up a little and put it back together and now things are working as they should. Thanks!
