190xt Power director pressure
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 1:03pm
You did check the bushings that are discussed above if bad the will allow the valve to not completely open.
1969 190XT series 3
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 6:04pm
Well it was a classic case of me putting the pistons in the pd in backwards, pressure pushed em out, sealing rings popped out of the housing, which would bleed off all the pressure and not allow it to have neutral also, keeping a slight pressure on the plates because the pistons wouldnt retract.
Carl
Edited by Carl(NWWI) - 17 Mar 2012 at 6:05pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 7:00am
The reason the Allis manual says to check pressure at T is because the first valves were not tapped for check pluges then they didn't rewright the servise manual.
 It is common to show some pressure in nutural.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 5:29pm
Yeah, mine did have early valve on it, put a later one on though. Everything works now, my low side pressue is 150 and high is 130. Put a washer/shim in releif valve didnt change any. could it be the pump?
Carl
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 9:09pm
What is your power steering like?
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 10:32pm
Its a little jerky/ turn stop, turn stop...... Kinda stiff but nothing to bad.
