190xt Hydro pump rebuild
Cfarmboy83 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cfarmboy83 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt Hydro pump rebuild
    Posted: 31 Mar 2024 at 4:07pm
Have a 190xt that needs the hydro pump rebuilt. Is Sandy Lake a good place to ship them or is there someone y'all recommend?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 4:23pm
Can't tell you anything about Sandy Lake. My question would be why do you think it needs rebuilding ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cfarmboy83 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 4:37pm
Pump is leaking towards the back half of the pump where the housing is bolted together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 4:59pm
The intake manifold can be removed in-chassis and replace the two O-rings, as long as the threads are good in the aluminum rear housing section. Four 5/16" bolts hold this manifold in place on the rear of the pump.
Edited by DrAllis - 31 Mar 2024 at 5:36pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cfarmboy83 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2024 at 5:32pm
Thank you. I will pull it apart next weekend.
