190xt hand primer pump |
johnny
Joined: 12 Sep 2009 Location: shawneetown, il Points: 317 |
Topic: 190xt hand primer pumpPosted: 09 Feb 2016 at 1:12am |
i have a 220 and a 190xt and both have primer pumps that leak as much fuel as they pump when using them. so today i made some changes to mine and got rod of the rubber plunger and replaced it with a sealed bosch pump as used on other tractors. cost about $30 to do the change and about 30 minutes,
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8731 |
Posted: 09 Feb 2016 at 8:32am |
Where did you get that pump from Johnny? Thanks, Darrel
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7530 |
Posted: 09 Feb 2016 at 9:19am |
The local diesel shop just rebuilt mine a few weeks ago. Roosa Master supplies a kit for changing out the seals on those hand pumps.
johnny
Posted: 09 Feb 2016 at 4:18pm |
darrel, i got the pump from my local pump rebuilder. i have bought the kit from agco but i have always got squirted with fuel when using the pump. with this bosch change i dont get squirted and it seals good.
EricPA
Joined: 13 Sep 2009 Location: Watsontown,PA. Points: 2578 |
Posted: 09 Feb 2016 at 5:31pm |
Maybe you should fix the fuel gauge
Life is tough,but it's tougher when you're stupid. - John Wayne
ac fleet
Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
Posted: 09 Feb 2016 at 8:24pm |
dealer here would NOT sell me any seals to fix mine, ---said I had to buy the whole pump at $ 185.----and I told them to kiss it and went 2 blocks down the street to napa and bought a electric pump for less than fifty bucks!---best thing I ever did for the 190! ( except to get the tractor sold, as I don't need it for my 5 acre garden)! thanks; ac fleet
Adam Stratton
Posted: 09 Feb 2016 at 9:12pm |
A quick search for the part number in the picture took me here (I ordered a couple one for my XT and for my 7000 (they both like to squirt too!)
also on amazon, but a little higher
johnny
Posted: 09 Feb 2016 at 10:30pm |
here is a link showing the steps i took to me this work.
http://www.grandpastractor.com/kunena/allis-chalmers/1493-190-diesel-hand-primer-pump-rebuild.html Edited by johnny - 09 Feb 2016 at 10:30pm |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5114 |
Posted: 10 Feb 2016 at 7:16am |
that looks like a pretty good setup, but I sell the complete rebuild kits for the primer assembly for around $70. The plunger is 45 of that. What you don't see are the 2 check valves inside that get clogged up with crap and create a major restriction of fuel flow to the pump. Those check valves are about 10 each. Putting on the Bosch primer does nothing about the 2 check valves inside. New replacement plungers don't leak either. Once that bosch primer is 40 years old, it will be leaking too lol!
BZRANCH
Posted: 29 Apr 2018 at 7:01am |
Where can I buy your complete kit?
orangereborn
Posted: 17 Apr 2019 at 3:33pm |
[QUOTE=johnny]here is a link showing the steps i took to me this work.
http://www.grandpastractor.com/kunena/allis-chalmers/1493-190-diesel-hand-primer-pump-rebuild.html[/QUOTE] So you just adapted the Bosch to the OEM barrel? Think that would work using an elbow so it is upright? That is plunger only? Still using the OEM valves in stock body? Thanks....Dale |
johnny
Posted: 18 Apr 2019 at 12:41am |
Yes Dale, I only adapted the new pump to the barrel and left all the original check valves and spring intact. I don't see why you couldn't put in an elbow it should work fine with one I would think if there is room to still pump the pump.
johnny
Mooreje1
Posted: 10 Jul 2024 at 8:36pm |
Do you have the primer rebuild kits for a 200 allis?
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 870 |
Posted: 11 Jul 2024 at 7:23pm |
I bought the rebuild kit from injpumped. Primer doesnt leak, works great. Only problem i had was allowing gunk to get into the check valves because i got rid of the sediment bowl screens and then left fuel cap off while mowing. I blew out check valves with air and they were fine. I recommend using original equipment.
oldways
Posted: 12 Jul 2024 at 7:40pm |
I did this to both of my 190xt about 2 yrs ago. Only way to go.
