190XT flywheel
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Topic: 190XT flywheel
    Posted: 30 May 2021 at 10:11pm
Anybody on here make the adapters for a big block Chevy steel flywheel to 301 engine? Otherwise I have a place that will make one. Might do a couple extras if there’s a need.
And what clutch has anyone used with that flywheel. I see the Chevy input shafts are 1.125” not 1.25” like an Allis.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2021 at 7:43am
I'd probably be interested in an adapter, and also the clutch info too- but you,d still be using the AC clutch the pilot bearing needs to fit in the Chevy flywheel
Edited by DougG - 31 May 2021 at 7:48am
Tim-tn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim-tn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2021 at 2:36pm
I use a clutch disc from a Ford truck if memory serves me correct. You will have to use a Chevrolet pressure plate or redrill the flywheel, I have used automotive pressure plates and clutch plates with no problems. Hope this helps.......
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 8:41am
Seems my One Eighty had a Mack truck clutch and pressure plate in it
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 6:40am
Most steel flywheels have more than one pressure plate bolt pattern, which are standard bolt pattern.
I used a Crower on GM flywheel.             MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2021 at 6:19pm
Mack , didnt you use a big block chevy flywheel and just redrill it ? Is that all it took ?
Edited by DougG - 14 Jul 2021 at 6:21pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2021 at 7:49am
Has to have adaptor  for rear crank seal.           MACK
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 7:54pm
I dont know if this is any help to anyone but years ago, running big block Chevys we used IHC truck clutches.   They bolted right up.
This page was generated in 0.101 seconds.
