190XT DUALS?
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: 190XT DUALS?
    Posted: 15 Dec 2011 at 1:20pm
I have a chance to buy a set of ALLIS CHALMERS duals with 18.4x34 tires one tire is flat it may just need air? tred is fair my ? is what are thay worth? THANKS TOM.
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 2:55pm
Clamp on or axel mount?
          IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 4:03pm
THAY ARE REGULAR ALLIS DUALS WITH THE BIG CAST IRON HUB
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 5:01pm
 that makes them worth getting utherwise they wouldnt be worth much. The hubs are probably worth 250 and the rims that if they are good.
                                               IG
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 5:07pm
THAY WANT $400.00 I AM TRYING TO GET THEM FOR $350.00
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:30pm
Does a i90 XT have long enough axles for axle mount duals? I don't think mine does. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 8:47pm
Yea they do. Depends where your cast centers are sitting on your axal. If your centers are pushed in and your wheels spun out there would be. I have had them on 190's
                                                 IG
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2011 at 11:44pm
my series 3 has axle  duals same thing as IG says it works  mine had the clamp on and i spun them when chisel plowing and bent all the clamps .this was when it was at 175+ hp   Shawn
190XT,D17and 7045
