190XT Dual Hubs
190XTJR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTJR Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Dual Hubs
    Posted: 27 Jan 2012 at 9:18pm
Hey guys I just bought my first AC, a 65 190XT it has had the rearend updates to large bullgears and large axles with 38 inch rear rubber. I was wondering how hard it is to find hubs to fit these axles so I can run hub duals. The reason I want to run hub duals is it is alot easier to find 38" hub dual rims verses 38" band duals around here. I will try to get pics up these weekend of the 190 and the story of this tractor. Thanks, DuWayne
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 9:27pm
Your axles may not be long enough to mount an axle hub for duals. You need the A-C 'flower pot' cast adaptor for duals. It bolts to the 6 holes in you cast center and has a 9 bolt pattern for a standard dual rim.
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 9:53pm
Calvin I put them on my 69 series 3 they worked fine. they are not spaced for row crop tho I will try to remember to get measurement this weekend. Are yours spin out or bevel rims.                   Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190XTJR Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 9:57pm
I have the spin out rims. How easy is it to find the flower pot hubs and what are they worth?
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 10:03pm
Flower pot hubs I don't kno either I have only seem one pair on my uncles .my hubs came with spacers and I didn't use them bout 8 inch or so the spacer bolts to hub and duals bolt to spacer . The ones I got are from a 200 but they are the same . They cost me 75 for the pair
190XT,D17and 7045
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jan 2012 at 10:46pm
 I have the flower pots, or the hubs for your 190.  PM me.
                                        IG
