190XT Arms won't lower
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: 190XT Arms won't lower
    Posted: 1 hour 60 minutes ago at 10:03am
I have a 190XT snap coupler. It had a 3pt conversion on it, the full system with torsion bar and everything. With that system on the arms would raise and lower properly. Since I've taken it off it only raises.
I know I have a full adjustment coming for me. But I don't have time, and it's cold as all bologna right now. Is there one quick adjustment I can make so the arms will at least lower by themselves, so I can get my equipment hooked up?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 28 minutes ago at 10:35am
Snap-Coupler lift arms will NOT lower by themselves on that tractor. Why??  Because there's back pressure in the hydraulic system and the colder the oil the more back pressure there is. The back pressure makes it's way to those lift cylinders and they go up. That's the way it is and has been since the tractor was built. Shut the engine off to get the arms down while standing on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 13 minutes ago at 10:50am
That was an easy fix!!
