190xt Ammeter
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt Ammeter
    Posted: 16 Oct 2025 at 9:35pm
The ammeter gauge on my 190xt will “surge” and then go back to 0, back and forth every few seconds. When I turn the lights on they get brighter when the gauge surges so is it safe to assume the issue is not the alternator since the lights get brighter? Possibly the voltage regulator or a bad gauge? I’m not great with the charging side of things so any help for a starting point would be much appreciated.
Edited by Travis2766 - 17 Oct 2025 at 7:33am
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2025 at 7:18am
I always try to try the simplest solution first.
In this case, the first thing I would check are all the electrical connections, especially all of the grounds. With age, a lot of these grounds became rusty, corroded or loose. Cleaning sometimes makes a world of difference.
If that is not the problem, my next guess would be the voltage regulator (after I checked the ground on it).
