190 xt transmission speed w/o PD ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt transmission speed w/o PD ?
    Posted: 20 Jul 2019 at 4:12pm
Whats the ground speed of a 190 xt without a Powerdirector say in 2 nd gear ? Is it the same as 2 nd gear low side ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2019 at 9:28pm
If there is no Power Director clutch assembly inside the tractor, someone has made a coupler to connect the transmission input shaft to the torque tube gears. So, depending on what they did/made, it could be direct drive (HIGH) or under drive (LOW).
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jul 2019 at 10:52am
Wouldn't direct drive be better ? As in turning less gears etc
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2019 at 7:43am
would be more "efficient" but only slightly and without the motor to turn it it wouldnt be any better
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2019 at 6:00pm
Interesting last comment as without a motor its just gonna sit there !!Lets break it down,,   My fault as the Power director clutch is out of the tractor and a coupler installed,,, will high side be less resistance on gear turning? And 8 th be the true 8 th?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2019 at 7:59am
haha, yes as the Dr. said  High is direct and low is underdrive, so 8th would be 8th not 7th in direct.   Turning a strait shaft will be easier than 2 geared together and my motor comment was referring to not enough motor as in pulling in 8th vs 7th.  Smile
Edited by CAL(KS) - 24 Jul 2019 at 8:01am
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2019 at 8:12am
takes a lot of power to pull direct! Hence a lot of motor! lol! Some tractors just cannot hack direct, so the option of running it in "7th" gear will help it pull better. Speed selection in pulling is usually dictated by the available hp!
This page was generated in 0.099 seconds.
