190 xt series 3
190xt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt MN Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt series 3
    Posted: 01 Jan 2020 at 11:41am
Hi I have a question on my 1970 190 xt. I have noticed that the crankshaft pulley has a slight wobble when the tractor is running. The pulley is not loose on the crank, and there is no visible cracks or damage to the polymer in the dampener that I can see. Also there is no abnormal vibration at any speed when the tractor is operating. Just wondering if anyone out there has the same issue, and if it’s a common issue. Should I be looking for a replacement dampener, or is it not that big of a deal. Thanks in advance for any replies!
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 4:25pm
I have a series III, but no wobble, a friend has 2 and no wobble, BUT I have a WD that has a nasty wobble in it. Every thing is tight and I am thinking that the crank is bent. ---- nobody has had any ideas on it so far.
bleeds orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bleeds orange Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 5:12pm
I'm not familiar with the 190's,but if it was me I would buy a new damper pulley.
They have gone bad on my 7010's.
What hurts them besides the rubber drying out and getting old ,is that they don't get cleaned that great. Dirt hay and everything else builds up on both end s of the pulley and helps throw them out of balance.
dbounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbounds Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 7:45pm
I have a 1970 series 3 also and mine was wobbling also. I was able to find a good one off a gen set and when I removed pulley the rubber was dry rotted and part was gone. I would replace or rebuild yours soon. I have seen post on hear before of someone on west coast that rebuilds them. Doyle
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 8:29pm
Dirt buildup on one will self balance.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 8:40pm
If it starts throwing belts,killing alternators or springing leaks in the radiator, replace it before you break the crank! Bad harmonics!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 8:42pm
Thanks for the replies. I appreciate it. Happy new year to everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 9:23pm
Has anyone done any business with dale mfg in Oregon recently? I’d like to send my pulley in to be rebuilt, but it looks like his shop might be closed. Hopefully not, that looks like it might be the most money friendly solution.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 9:53pm
Yes Dale mfg. has been used by others on here and recommended. He did have certain times his shop was closed for other interests. Hope he hasn't closed permanently. Check previous posts.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 10:45pm
Just sent my 190 one there in November. Fast and did a great job! $230
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt MN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 6:10am
Thanks everyone for the info. I will have to give him a call. Hopefully he’s not done rebuilding them!
Red Bank View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Red Bank Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 6:41am
He did mine for my 200 if I remember correctly he takes every other month off.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 7:01am
He did the one for the 426 in my L2. Good deal and quick but like others have mentioned he doesn't operate full time and takes certain months off from that business. Just give him a call.
Wink
I am a Russian Bot
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2020 at 7:08am
to a point if the pully has a section of raised balance inside it csnt balance itself . it was such a problem on deere combines movrd the weight to the outside
