190 XT reverse shift lever
festus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT reverse shift lever
    Posted: 30 Nov 2024 at 6:49pm
   Broke the lever today. It looks like these are almost impossible to find. My tractor appears to be a 64 XT gas. I see where some have been able to braze them or in some cases weld them back together. This one broke on the flat part a little above the numbers.
I'm a little Leary of brazing it and expecting it to hold. Make I am overthinking it. I am assuming it is cast steel so welding may be a decent option. I have an Ac stick welder and A wire welder which I assume is a no. Will An old fashioned Lincoln Ac buzzbox work for the needed rod? What rod would you recommend?
 Will another shift cover with the levers attached interchange with mine? I found a case where a guy found another lever from a yard , but it was different than his. My rails were rebuilt 6-8 years ago so I would prefer to use it if possible.
The part number on mine is 246554
Thank you for any suggestions
Joe Goodwill View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Goodwill Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 7:06pm
We broke the reverse shift fork on a 185 30+ years ago on a weekend during a blizzard! Opened it up took the fork to local shop where old AC mechanic worked. He was a master with brass and a torch. 15 minutes to fix 1 hour to enjoy the bottle of dark rum payment and it is still working today. Don’t be afraid of a proper brazing repair.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 8:14pm
246554 looks to still be available
elmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote elmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 10:33pm
Thanks Joe . That gives me some hope if it comes down to that. I used to have to braze  together 2 oil pick up tubes on Chevy race engines years ago. It has been several years since I have had to do any brazing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote elmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2024 at 10:34pm
Mikez ,
 Where did you find that available?
 Thank you
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2024 at 6:30am
Agco still sells them. Bargain price of $782 according to the online parts book. I'm pretty sure I have a good one laying in the shop I'd sell for $50 plus shipping. Im in east central Iowa
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2024 at 8:03am
add a "70" to the front of that part number when you GOOGLE... A few used ones around but they sell pretty fast..... grinder has a GREAT price aat $50.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2024 at 8:11am
or NEW...
Post Options Post Options   Thanks (0) Thanks(0)   Quote elmer Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2024 at 11:06am
Grinder Thank you for the help.  I am also in Iowa . What is the best way for me to get you paid?
 I just figured out how to send you a PM so my information is there.
 Thank you !
Edited by elmer - 01 Dec 2024 at 11:12am
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Dec 2024 at 11:25pm
I took mine out several years ago took it to a local black smith. He brazed it back together. It’s working great. a good braze job is just as strong as the cast part was to begin with. We brazed a shift fork on dad’s dozer back in the 70s. It was still working 20 years later when he sold it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote elmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 2:25pm
Got the reverse fork today from Grinder220 below. Thank you sir for your help!
 Now I have to change it. When I try to take  the rail out to swap the lever will there be a detent ball to catch like the other rails?
 Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 3:12pm
I'd assume so. What else keeps it in place? Be prepared....
Post Options Post Options   Thanks (0) Thanks(0)   Quote festus Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 8:05pm
Thank you.. haven't had one apart all the way have seen where people loose the ball. Hopefully I can get it apart and get the lever in the correct spot without loosing parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2024 at 8:43pm
Best and easiest thing to do is get a bolt or rod the same size to but up against the shift rail so the ball and spring stay compressed. You can rotate the rail enough to get out of the detent and it will slide out nice and easy.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 6:38am
That's a great idea!!!
Maybe this should be in the Knowledge Based section as a reference to anyone that tackles this job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote elmer Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2024 at 12:27pm
 Thank you
