190 xt putting pressure in the cooling system
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt putting pressure in the cooling system
    Posted: 28 Jul 2019 at 9:28am
Got an XT that just after a minute or two running its putting pressure in the cooling system, have a antifreeze jug as a catch can - and it spits into there pretty good,, Im guessing its the head gasket, any other options ? Does anyone make an all copper head gasket better than Agco ? This has the 450 injector pump head and pushing a lot of fuel
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 10:00am
I have MLS head gaskets and drop on fire rings, or fire rings for cut sleeves. A 301 with a 450 pump would definitely blow a stock gasket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 10:27am
Ok thanks Ed, while its off Im thinking of having it ported and polished - or do whatever to get it to flow more air, any recomendastions there ?
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2019 at 3:33pm
426 valves, pull the sleeves, cut for rings and notch for clearance.
This page was generated in 0.083 seconds.
