190 XT puller- head issue -blowing water out
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT puller- head issue -blowing water out
    Posted: 11 Aug 2019 at 1:25pm
Pulled the head off the 190 XT puller this morning, its been blowing water out of the radiator after 30 seconds of running,found its got a copper head gasket already, I've been away from this for a bit= and guessing its a cracked head causing the pressure in the radiator,, also found a valve insert cocked in causing a stuck valve,, looking for options, buy another head and put my stuff in it, or send it to a machine shop , have it tested and welded? This tractor has a 450 pump head on it, valve cuts on the piston,,, its built for power
Allisplumber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allisplumber Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 10:15pm
I would find a different head , take out the stock valves and seats , cut it for 426 valves, the pistons are already cut .
