190 XT PTO Help
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Topic: 190 XT PTO Help
    Posted: 24 Nov 2021 at 3:25pm
I've never used a 190 and a friend traded for one and the PTO lever is stuck apparently. What does the lever on the side of the console do? It is a 1970 model Ser #28233.
'59 D14 '68 170 Diesel '81 7020 40 All Crop
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 4:07pm
if the lever is on the right side mounted on console. Would be hydraulic controlled pto. Try checking oil level to start. If hyd pto it will have hyd lines going to pto housing under tractor.
Edited by Mikez - 24 Nov 2021 at 4:07pm
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 4:34pm
The lever has 3 positions.
All the way up engages PTO
Middle (lever is about level) is neutral
Lever down is off with PTO brake engaged
When disengaging PTO always let it come to a complete stop before going to the "Brake" position. Pushing in on foot clutch will make it come to complete stop sooner.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 5:44pm
It has a rod sticking up through the floor board to the left of the trans case that should pull up and down. it is stuck. What is that for?And just for the record, the foot clutch kills the PTO like the smaller tractors, right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:09pm
Yes the foot clutch kills the pto no matter if it’s mechanical or hydraulic pto. It’s hydraulic if is on the console. 3 positions, pushed down its off and brake is applied, midway is off and in neutral so to speak, fully up is engaged. When pto is engaged always move to midway to shut pto off. Only move to full down after the pto is completely stopped to engage the brake.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:12pm
Sorry KyAllis, I overlooked your post.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:37pm
The push/pull lever to the left and at the platform shouldn't be there if it has a hydraulic PTO. So, if it is there it needs to be pulled up I'd say 6 or 8 inches to engage the sliding coupler. You'll have to mate the splines, so it may not pull up with the engine off and nothing turning. Yes. Foot clutch still kills the PTO rotation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:41pm
Does it have hyd lines to pto
Edited by Mikez - 24 Nov 2021 at 7:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 8:30pm
Mike Z yes I think it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 8:30pm
Ive bought and sold a few 190,s - wasnt there some that had the pto engage on the left by a movement of the lever to the front to engage it ?
Edited by DougG - 24 Nov 2021 at 8:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 8:33pm
I've got one more question. On a XT Diesel does the serial number supposed to end with XTD or DXT. I have another friend that has one with DXT but I don't think that is right.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 9:38pm
Doug is right too, I've got one of each on the farm right now. One you pull a knob up to engage and it's just above the floor when disengaged, the other you shove the lever forward to engage and pull back to disengage. Have your foot on the clutch when moving either type either direction.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 9:41pm
XTD is a diesel XT. Has nothing to do with PTO type. A hydraulic pto doesn’t have a floor engagement lever. And a mechanical doesn’t have a console controls pto lever period. Hydraulic pto was a option.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 9:41pm
The detent balls for the side lever need some lube have seen handles broke off and welded on because they moved so hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 9:51pm
I would be surprised a series III would be mechanical. I would have thought it would be hydraulic as standard equipment in that time period but I could be wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 12:33am
Hyd. PTO was optional on XT series 3 and even on the 200.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 11:55am
Dad bought a Series 3 XT brand new in 72 with the mechanical pto. Still have that tractor.
Leon B MO
