190 xt 3
190xt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 190xt MN Quote  Post ReplyReply Direct Link To This Post Topic: 190 xt 3
    Posted: 26 Mar 2021 at 8:32am
Hello. I have a 1970 series 3 xt and was wondering if it can be converted to the 540/1000 pto option if a person found the right parts. I’m thinking the 2 speed setup would be the same on a 200 also? I read a post on here about guys switching to the interchangeable pto on 7080’s and 8070’s and I realize that’s a whole different tractor, I was just curious in I could do it on my xt. Thanks in advance for any replies.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 8:58am
It requires the lift housing, the pto shafts, the 1000 rpm drive box (or driven gear) and the 1000 rpm driven idler gear. Note that there was a gear change at sn 9001.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 9:02am
i believe you have to change the intermediate gears in the torque housing and then you need the 2 speed housing and required parts at the back
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 10:15am
sounds like the answer is YES if you have all the pieces,time,skill
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 6:49am
We installed a 540/1000 pto on our XT several years ago. I don't remember exactly what all we switched but we had a complete parts tractor to steel what we needed. We did not change the manual engagement parts. So, it is a 540/1000 with manual engagement with the long lever under left side of seat.
Leon M MO
