190 weak 3 point
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Topic: 190 weak 3 point
    Posted: 08 Jul 2017 at 12:25pm
My 190 has  a weak 3point. Im moving the pallets of lumber for my new shop.  so I put the Pallet fork on the WD 45. it lifts the front of the tractor about 3 feet off the ground and teeters the stack of lumber. So I put the pallet forks on the 190 it wont budge the stack of lumber.  I picked up one end of the pallet of steel with the WD45 loaderand a strap so i could get the forks under it.  the 190 wont lift it. I dont have a factory three point but a conversion on the snap coupler setup. But I really think it should lift more than it does. is there a relief valve stuck somewhere that I should be able to find?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 3:47pm
Pressure at any remote outlet when holding a lever into raise or lower should be 2,000 to 2,200 psi with engine half throttle or above. If lower than that....a weak 3 point hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2017 at 10:11pm
Thanks I'll try to get a guage next week when I'm at the farm. If I speed it up to 1500 rpm it works much faster.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 12:24pm
Hyd on a WD45 will work at an idle.  190 XT at an idle won't do much at all.
This page was generated in 0.057 seconds.
