190 vs 200 speed |
brad durst
Joined: 20 Aug 2018 Location: richland center Points: 85 |
Topic: 190 vs 200 speedPosted: 03 Nov 2018 at 8:30pm |
is the gear ratio in a early 190 threw the 200 the same? with 18.4 38's are all the wheel speeds the same. i was thinking the 200 was faster but is the tire size the only thing that sped them up. thanks
Posted: 04 Nov 2018 at 5:43pm |
Direct drive road gear is the same. The use of D-19 bull gears speeds things up a bit.
brad durst
Posted: 04 Nov 2018 at 6:11pm |
dr allis i have heard that the 2oo ring and pinion was different. is it. thanks
Posted: 04 Nov 2018 at 7:22pm |
That is true, but it is still the same ratio.
Posted: 04 Nov 2018 at 9:46pm |
180/185/190/190XT are 9 tooth pinion gear and 35 tooth ring gear for 3.89 to 1 ratio. Model 200 has 10 teeth pinion gear and 39 teeth on ring gear for 3.90 to 1 ratio, essentially the same. D-19 bull gears are 6.58 to 1 versus 7.15 to 1 for an 8% speed increase. 180/185 are 5.85 to 1 in the final drives for an 18% speed increase over any 190/200 final drive.
brad durst
Thanks(1)
Posted: 04 Nov 2018 at 10:25pm |
so a 190 if it has the same size tires is faster than a 2oo. will 180 final drives bolt on? do you make a manual coupler that will still let me use the hi side and the low side?
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35560 |
Posted: 05 Nov 2018 at 6:36am |
You do understand the theory in the finals of the drop reduction finals is very different to the straight axle differentials on the larger tractors? The delivered torque is what was after NOT speed, put all too much HP and delivered engine torque on the deep reduction axle ends and they will fail, put those lower HP/torque engines in the straight axle tractors and they labor to produce. There is a means to an end but it was NOT speed.
Posted: 05 Nov 2018 at 7:03am |
180/185 final drives only fit on a 180/185 rear end housing, so that is NOT an option unless you swap the whole rear end. If you are being outrun by another 190, he is either using D-19 bull gears, tires that are taller, more engine RPM or all three things. He could also be using (only ever knew of one of these) a 200 rear end with a 190 35 tooth ring gear matched to the 10 tooth pinion (instead of the 39 tooth 200 ring gear) for a 10% increase in speed. I do make a two-speed coupler to replace the Power Director clutch so you still have all 8 gear selections.
brad durst
Posted: 05 Nov 2018 at 11:25am |
dr allis thank you very much. are all d19 bull gears the same gas to diesel ect. dmiller yes i do understand that. im trying to speed things up so. i am running a class with a 20mph pace. so i want 7th around that and 8th 25 plus. open rpms so im figure i will be around 3500 rpms going down the track. maybe im way off?
Edited by brad durst - 05 Nov 2018 at 12:42pm |
Posted: 05 Nov 2018 at 3:44pm |
D-19 gas and diesel are the same. You want to avoid a very old model because they had bull pinion coarse splines into the differential side gears. You'll want the later model bull pinions with the fine splines.
