190 triple hydraulic pump kit?
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Topic: 190 triple hydraulic pump kit?
    Posted: 28 Jan 2025 at 12:48pm
AGCO or aftermarket? Is there a quality difference? Friend of mine bought a hydraulic cylinder kit from Cat for his trackhoe for something like $500 and when it came the part numbers on each seal was the same and looked the same as the aftermarket kit he bought for the other cylinder at the same time. After market was less than $200. Is AGCO going to just mark up a seal kit that they get from the same supplier as AGParts or Steiner?
Wink
I am a Russian Bot
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 10:29am
24d0001 or 3 of 70255947 or
2 OF20-7300762
2 OF 20-7300763
2 OF 20-7300764
per section
70241139 is the seal for the old pump 70250324 for the late style
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 10:44am
Agco and ALL the bigs DO NOT MAKE PARTS out side of housing and gears - and some of that is outsourced.  It is like the customer who went to Moline and watched his American made tractor being built - then got to looking out back and saw crates from France, Brazil and China galore.  We pick and choose. Some customers specify - I want the 'good stuff' now so we use Agco - they do have 1 year warr and all parts - but it is the same seals as A&I and others. Cessna stuff - who ever supplies this.  The 20-xxxx #s are from the old Oliver stuff. Takes mulitples - the 24d0001 is about $250 and includes seal for the newer pumps...
Edited by tbran - 29 Jan 2025 at 10:44am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jan 2025 at 11:45am
In the last couple of years, I have resealed a 180 and 185 hydraulic pump and got the seal kits from A & I. Was happy with the parts and both pumps work well.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2025 at 11:36am
When I went through mine a few years back Hammell Equipment said I had gotten some of the last gears AGCO had available at that time.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2025 at 9:53pm
Thanks guys. I'll take all this in to account. I appreciate it.
I was running a disc mower with a remote in float position and after a while the hydraulics got so it wouldn't lift. Took a few times before i realized the oil was probably getting hot. I would stop for a few minutes and it all worked again. So I quit using float to control the cut bar. Second mowing last summer is when it all quit. Remotes won't gain pressure and neither will the lift. Power steering is fine and position control seems to work. It has been since summer that I looked at it last. Tractor is a 1965 straight 190 and has no hydraulic oil cooler. Dad's 1965 XT has an oil cooler. Didn't realize the early ones may not have a cooler. Tractor has 3900 original hours.
Edited by Lonn - 01 Feb 2025 at 10:04pm
Wink
I am a Russian Bot
This page was generated in 0.227 seconds.
