190 trans rebuilding
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: 190 trans rebuilding
    Posted: 15 Jan 2017 at 3:36am
Ok so I was priceing out new pinion bearing at the dealer and was told that the bearings were 400.00 for the two of them.
My question is there a cheaper route and does any one have part numbers for a cheaper route.
O I forgot this is a two spider diff
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 7:05am
Is your bearing bad or just need adjusted?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 7:32am
Get the name and number off the old ones and go to IBT or another bearing supplier may be able to get the same without a 500% markup , worth a try
Edited by DougG - 15 Jan 2017 at 8:09am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 8:50am
The bearings are rusted from siting with out oil and one is bad
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 5:58pm
NOT SURE WHAT YOUR SERIAL NUMBERS IS BUT,
YOU CAN GET THESE BEARINGS FROM NAPA.
THESE ARE FOR THE CARRIER BEARINGS (SUPPORT THE RING GEAR)
AC #211169        NAPA # 387AVP   $17.87
OR
AC#244167         NAPA# BR45291   $39.16
THESES ARE THE PINION SHAFT BEARINGS:
AC #223308        NAPA #  BR3780     $26.92
IF YOU GO TO AGCOPARTSBOOK.COM YOU CAN FIND YOUR PART NUMBER AND I CAN TRY TO CROSS IT OR IF YOU  CAN SEE THE NUMBERS ON THE OLD ONES YOU CAN TRY THOSES NUMBERS.
DAN
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2017 at 8:44pm
We are working on getting it apart. sofar it's slow not much spare time but we're getting it apart.
Thanks for the info dan.
