190 temp gauge
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Topic: 190 temp gauge
    Posted: 06 Apr 2010 at 8:27pm
Over the past year the temp gauge on my 190 has begun to read low, is it the gauge or the sending unit? Is there a way to test it?
Troy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Troy Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2010 at 8:44pm
ground out the wire going to sender with key on. should read max hot. if does then you have a sender problem or a thermostat that is stuck open if not warming up!
