190 spindle bushings
Josh(NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Topic: 190 spindle bushings
    Posted: 24 Jun 2017 at 10:26pm
How nasty of a job is it to get the drag links off, and bushings out? Any pointers are welcome.
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 8:40am
Remove snap ring, remove knee assembly, turn upside down, slide back in, and with a big sledge drive down on arm.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2017 at 12:08pm
Wish mine was that easy. I had to take a chisel and cut the groove vertically to get mine out. I guess after almost 50 years they had rusted in there even though Grease was abundant. Once i made the slot bigger were the 2 ends of the bushing came together I used a long flat screwdriver to get under the bushing to pry it out. Hope yours goes better. It really shouldn't be a hard job, but mine was very agrevating
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 1:31pm
The last one I removed, I ended up splitting it to get it off and replaced it with a new one.  If I remember correctly, that is how the service manual says to do it. I pulled one before and it took me the better part of a day to get it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh(NE) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2017 at 10:24pm
Got one side apart tonight, I believe it is the worst worn. Looks like I will need a spindle and knee. Anyone have any experience with aftermarket, A&I or Abilene machine as to the quality of the parts or should I be looking for salvage parts? Thanks
Allis Express
