190 Rear axle pusher bolts |
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7451 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Nov 2016 at 9:04pm |
I read through the earlier posts about how to remove 190XT wheel centers from the wedges. I have not been able to get my hands on any authentic pusher bolts locally, nor do I want to pay an outrageous price for something I am probably only going to use once.
It looks like I can fit a piece of plate steel between the wedge and center and thread 3 bolts against it. Here is my question: Does any one know the thread type in the wedge? A regular national coarse thread bolt only seems to turn in one round. Yes, I did clean the threads first. In the earlier posts, Mack mentioned that the threads were different, but did not give details. I would appreciate more insight about these things. Thanks! |
hillmonkey ![]() Orange Level ![]() ![]() Joined: 03 Apr 2010 Location: oville fl Points: 417 |
http://www.allischalmers.com/forum/forum_posts.asp?TID=106054&title=190-rear-wheel-removal
190 has a standard 3/4 course thread. The 7010- 4w305 have the odd threads. If you put a steel plate behind wedge, use the thickest steel plate that will go in and use grade 8 bolts. Also oil threads and end of bolts. MACK
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
I tried a plate once and ended up punching an ugly hole in the plate and took out the first thread in the wheel. No real harm but I then went and bought a set of pusher bolts from AGCO. That was 20 years ago and they were only something like $3 or $4 a bolt back then.
Wink I am a Russian Bot |
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3023 |
I had to take a hub off the D19 years ago think I used grade 8 bolts as a pusher with sightly sharpened ends and a size smaller nut to press with and an impact.The impact jarring everything made them come right loose.
