190 question
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: 190 question
    Posted: 13 Mar 2011 at 10:10pm
190 gas idles rough not sure if timing is off, or could carb be not functioning right, is there any specs on gov/throttle linkage, it idles ok , but when i put in  gear it misses  then runs ok when moving , but no power, carb is getting gas and has always worked good. I just replaced engine so had to retime, and not sure what next?
1959 D 17 gas , 1964 190 gas, 1965 190xt gas AC 4bottom slat plow, 6 row 30in #72 planter Im not getting bigger my cloths are just getting smaller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 6:38am
What kinda gas you using ; lately anything older  I have gas powered runs like crap ; plugs are trashed in a couple days etc; may be a place to start
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 7:33am
what all have you replaced for ignition parts? Could be plug wires, coil, points, distributor or just the cap. On my 190 gasser, I replaced all of that stuff (except distributor), put a flame thrower coil on it, electronic ignition, and it has run good for over 2 years, except just the other day the carb iced up, but it got over that pretty fast. It does cough and sputter when it's cold, but as soon as it gets up to operating temp, it runs good. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2011 at 4:07pm
i pulled off each wire one by one as ir ran and all were working , (it was noticable)  i started it today and it turn over for a bit before it started witch is unusual, then it idled ok then when pushing lever for gas it surges and no power, like governor doesnt know what to do or maybe carb is plugged , it worked fine on other engine. I havent replaced ant ignition parts.
