190 Question
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Topic: 190 Question
    Posted: 22 Mar 2017 at 9:28am
Is the engine the same for the 190 and the 190xtIII and the fuel pump also?
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 9:48am
Sorry, I don't know the differences, but as a forum suggestion, it'd be a great knowledgebase article to build the difference between the 226 gas engines and the 301's. I'd be willing to help build the topic for the 226 although there's a lot that I don't know. I don't know much at all about the 301's
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 12:32pm
No, the gas or diesel engine is different from a 190 to an XT. The fuel pump on the diesel is calibrated to a higher fuel delivery on the XT to go along with the turbocharger. Both Diesels are 301 cid and pretty much the same, other than oil cooler. The gas 190 used a 265 cid, the XT gas used a 301.
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 1:13pm
Ok,   I said it wrong.  It is a 190xt engine.  Is it the same as the 190xt III?   It has turbo?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2017 at 2:07pm
Late series 3's had a different injection pump with an advance for better starting. Any series 3 I've seen had an AirResearch TO-4 turbo instead of a Thompson/Rajay turbo.
This page was generated in 0.107 seconds.
