190 owners |
boscoe
Topic: 190 ownersPosted: 25 Feb 2011 at 4:57pm |
What kind of oil goes in transmission, I think 9gal capacity total , oil supply to transmission, torquehousing , rearend, pto all the same oil
BLee Mn
Joined: 12 Sep 2009 Location: Montevideo Mn Points: 685 |
Posted: 25 Feb 2011 at 5:12pm |
beleive allis oil would of been 821, i use JD hydralic oil i all my tractors
Cowboy UP
boscoe
Posted: 25 Feb 2011 at 7:57pm |
rear end is 80-90 all other is hyd fluid, agco, JD or CIH brands seem ok from what people tell me.
Pete from IL
Joined: 29 Dec 2009 Location: Beecher IL. Points: 314 |
Posted: 25 Feb 2011 at 10:41pm |
Only the final drives on a 190 take 80w-90. The rear end and transmission takes 821 hyd. oil 0r equivalent.
boscoe
Posted: 26 Feb 2011 at 7:37pm |
Where do I refill final drives, I see drain plugs , so I can drain, also I drained and filled pto-torquehousing-tranny, It wasnt good fair amount of water in oil , so i should probably drain rearend too and that takes HYD oil also, iwill rearend drain completely?And final drives take 80-90. |
boscoe
Posted: 26 Feb 2011 at 8:08pm |
is there somewhere where water leaks inthe tranny and rearend that has been aproblem for others
1959 D 17 gas , 1964 190 gas, 1965 190xt gas AC 4bottom slat plow, 6 row 30in #72 planter Im not getting bigger my cloths are just getting smaller.
Posted: 26 Feb 2011 at 8:19pm |
Yeah, there's a flat rubber seal on the gearshifter bell that's probably gone and the metal platform cover that actually covers the shifter with the missing rubber seal is probably missing too. Keep it in a shed out of the rain works good.
boscoe
Posted: 26 Feb 2011 at 10:13pm |
I will look at that tommorrow, it would be a cheap fix compared to new fluid every year. I try to keep tractors in shed as much as possible. Anybody have a pic of how governor and carb is connected together.
ironac
Joined: 06 Jan 2011 Location: Plainfield IA Points: 283 |
Posted: 26 Feb 2011 at 11:42pm |
i just use harvest king universal hyd/tranny fluid. i have a loader on mine. works great
