190 or 190 xt |
tractorman ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: west central wi Points: 1046 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jun 2011 at 9:26pm |
just got a 190 diesel home. Was told it is just a 190, but the tractor serial # is 24505xtd. SO what is it ???????????? a g2800 engine and no turbo if the turbo was the detemaning factor and doesn't look like one was taken off. Looks to be real straight and not worn out. Since it is a flat back that eleminates some of the ppossible history of heavy plowing. Any thoughts will help.. Tman
Dean/MN ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Oak Grove, MN Points: 740 |
Without a turbo it's a 190 not an xt. Is it possible that the engine is a transplant?
HD16,917H,185,7050,8030FWA,8050FWA
DaveCinIN ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Kouts, IN Points: 629 |
SN says it was an XT diesel. G2800 is a gas engine. Something has changed.
Hurst ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |
G2800 = gas 301, right? If so, that would be a 190xt gasser, but the serial number ending in xtd would be a diesel xt, right? Maybe it was originally a diesel 190xt and had a gas 301 transplanted into it?
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Hurst - or it was a 190XT gas originally and a torque tube/rear end was swapped in from an XT diesel tractor. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8338 |
Its real easy to break em in half at the torque tube and - make - a tractor ; aint a bad thing just hope they dude kinda knew what he was doing
