190 Loader Plumbing Confirmation
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: 190 Loader Plumbing Confirmation
    Posted: 07 Jan 2026 at 7:32pm
Finally have a joystick and everything mounted, looking to plumb. I read through this:
https://www.allischalmers.com/forum/joystick-install-with-pictures_topic138644.html?KW%20
And think I understand open center and the concept correctly.
If I replace the union part "2" with 2 90s, then fluid would flow from pump through line "3", through elbow to loader valve in the red line. Then out of the yellow going to an elbow and line "7" . I have the power beyond plug, and this green line going back to tank. For rebustness sake is like the return to go through the filter, can I just do a T at part "15"? Or would it be better to just Tee off the drain plug?
tbird View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbird Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 7:59pm
have a c motor  smokes just want to get rid of it  150.00  in eastern iowa
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2026 at 8:04pm
Here's the sketch I made and forgot to post above.
calico190xt68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:49pm
Don't know if you saw my post on adding a joystick and loader to my 190XT, but here it is in case it helps.   There are lots of pictures.  It works good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 8 minutes ago at 8:26am
Can't believe I missed that post!
Ended being almost exactly what I'm doing. But I decided to tap into the drain plug for return instead of at the filter. It's not as pretty, but I think it'll be simpler than dealing with the hard lines at the filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote calico190xt68 Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 22 minutes ago at 7:12pm
This site has so much history, it is hard to find it all. You also have to do an advanced search to change to Any Date. Otherwise, you only get the last 6 months. Always do an advanced search. Sometimes I go to Google and do a search there and it finds stuff on this site.
Glad you have it working. The devil is always in the detail.
