190 lift arm repair |
Rodd
Topic: 190 lift arm repairPosted: 30 Jun 2012 at 11:00pm |
This morning I began the repair on my leaking lift arms. I removed the outer snap ring, removed the splined arm with little problem, I soaked it down with wd 40 and wired brushed the splines first. Now my question is there something else around the shaft? I could see no other snap ring, and does this have O rings or a regular seal? I hope to order parts monday to finish this repair.
Thanks' Rodd |
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 30 Jun 2012 at 11:27pm |
I think there might be a felt seal in the arm or next to it. I have also found a thin flat washer between the arm and housing...not sure of the purpose. There shouldn't be much oil that gets up that far.
ALLIS EXPRESS!
This year: |
JimWenigOH
Posted: 01 Jul 2012 at 6:57am |
Rodd,
Go to the AGCO website and look at the parts diagrams. They will show you everything you need to know as well as the Part Numbers. There is only an o-ring to seal and one steel washer per side, unless an additional washer was needed to set the end play.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7579 |
Posted: 01 Jul 2012 at 9:43am |
After 40 years, they tend to get rusted on to the splined staft. Feed the oil to it and tap with a hammer to try to loosen it.
