190 Holley Carb |
PA185 ![]() Silver Level ![]() ![]() Joined: 08 Mar 2019 Location: Pennsylvania Points: 51 |
![]() ![]() ![]() ![]() ![]() Posted: 13 Nov 2020 at 1:54am |
I’m putting together a 260ci engine right now, ported, polished, C5 performance manifold/header, Blackburn cam, now it comes down to a carb choice. I have a bendix off a 190, and a Holley off a 190. Opinions on which carb would be better choice? I’ve heard the Holley is great when it’s working proper.
DrAllis ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 13489 |
Bendix from a 190XT G-2800 engine, not a 190 G-2500 engine.
I was using the term 190 pretty much as an umbrella for the 190 & 190XT. If there are differences in the carbs (positive there is) I’m all ears.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 2891 |
I am running a Holley on a CA. It is easier to tune as it uses the same jets as all other Holley carburetors. Although the drawback is that very few parts are available for them. About all you can find are gaskets and floats, unless you come across NOS parts.
I have a very large NOS Bendix/Zenith available. Edited by PaulB - 13 Nov 2020 at 7:02am |
If it was fun to pull in LOW gear, I could have a John Deere
A G-2800 carb is more air flow and jetted to match.
48ACWD ![]() Silver Level ![]() ![]() Joined: 06 Jan 2013 Location: Pennsylvania Points: 195 |
I have a carb off of a G combine 301 motor if anyone is interested.
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 5938 |
Are you making a custom adapter for the manifold? Or will it bolt up?
Charlie
The header is going to be tailor made to the carb
Robacpuller ![]() Orange Level ![]() ![]() Joined: 07 Apr 2016 Location: Wisconsin Points: 226 |
1.70 ratio roller rockers will help give it some more torque. Make sure u degree cam.
Call or text 608 228 4843 Rob |
1.70 ratio roller rockers will help give it some more torque. Make sure u degree cam. $275 plus shipping
Here r pics of finished rockers.
Anyone else have some input or experience running either one?
Edited by PA185 - 17 Nov 2020 at 3:17am |
