190 gear jumping
Message Reverse Sort Order
 Rating: Topic Rating: 1 Votes, Average 4.00  Topic Search Topic Search  Topic Options Topic Options
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Topic: 190 gear jumping
    Posted: 02 Jul 2017 at 1:34pm
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 12:33pm
Thank you, I will try that first. It didn't seem to jump 3rd but it does 4th. I didn't realize that you could get the shift fork new, I was thinking I would have to find a late 185 parts tractor. When I pull the shift cover off I should be able to see if the cogs are wore on the gears from there right?
Edited by 7060 - 02 Jul 2017 at 12:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2017 at 12:15pm
70261443 is the deeper shift 3 & 4 shift rail.......70261385 is the new fork.   You should replace these parts anyway when replacing transmission gears, so why not start there and it might fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 11:11pm
Any good partsman can get you what are the latest model parts.  Seems like the fork was 70261385  ??
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 12:16pm
Do you know about what year or when the serial number break was on the 185 shifter?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 10:39pm
Make sure it has the deep shift rail and fork from a very late model 185 and it may fix it without a teardown.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 9:43pm
After market parts are available.  Got some in my XT.  As far as what else is required, you won't know until you tear it down.  In all the gear jumpers I've been involved with, sloppy bearings were a good part of the problem.  My XT also needed a new input shaft.
I hope you are getting that tractor dirt cheap!  You will be looking at $2000 in parts alone for a proper fix.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2017 at 9:15pm
I know this has been talked about quite a bit, but I'm looking at buying one that I know jumps 4th. I've read that it requires disassembling the rear end, but are the parts all still available? Would it need 3rd and 4th gears, slider, and shift fork or what might be required?
