190 gas governor issue and others
boscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boscoe Quote  Post ReplyReply Direct Link To This Post Topic: 190 gas governor issue and others
    Posted: 26 Sep 2010 at 3:40pm
190 gas has a 2800 gas from a combine , not sure which combine, it runs ok , but they never changed over the front cover plate so now the engine runs without a governor, like a combine. Can this hurt the engine  to run without governor. the combine engine is a 1968 year. should i change front cover right away or can i run it some as it is. the throttle is makeshift connected to the carb. thanks for any help.
This page was generated in 0.057 seconds.
