190 diesel |
tractorman ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: west central wi Points: 1046 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jun 2011 at 7:35pm |
I am looking at a 190 diesel for about 4 bills, have some service history that seems good, may slip in 4th high ( high/low ) NOT GEAR JUMP OUT. any special points to look out for? had a 190 gas before and it loved gas, i assume diesel will be better. No three point, but would be used mostly for mowing and baling any way and a loader would go on it, rears are 20% or so. Will appreciate any pointers
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
What series is it? Is it an XT? If it's a 190XT, then the price seems about right considering the missing 3pt, and the worn tires. I would be cautions of the Power Dirrector slipping, it can be simple, or very costly!!! Otherwise, any 190 is a great tractor, IMHO
Still in use:
TedBuiskerN.IL. ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
If it doesn't have the three point hitch it may be a snap coupler version.
its not a snap coupler , but its not a true flat back either it has pto and the housing for the lift arms. Just no shaft sticking out of the housing , the holes are plugged.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8338 |
Im thinking about $2000 for that one -1500 if the powerdirectors slipping ; you will find that no 3 pt is gonna be a big deal when you want to do stuff with it ; 3 pts are great , so many attachments and versitile ; the 190 is a very good tractor but the pd slipping can run into bucks if you cant work on it yourself
