190 Control Lever removal
MadCow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Topic: 190 Control Lever removal
    Posted: 30 Dec 2025 at 4:15pm
Can the pins holding the hydraulic, throttle, and other control levers be removed, in order to swap the levers, with a cab and/or fenders on?
The throttle on mine was welded up and looks gross and a couple of the others need to be straightened. What's the trick to get these levers out?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 8:48pm
With the cab and fenders on?  No.  I removed mine by pounding the pin from the outside in - took a lot of work, been there for 60 years!  Remove the aluminum cover on top and you will access the levers.  It is still a very tight fit though.  Disconnecting the levers from the rods are hard to do in the space provided.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MadCow Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2025 at 8:58pm
I was hoping you'd have a sweet trick to share. Thanks with! Now I won't spent my days banging my head for no reason
This page was generated in 0.054 seconds.
