185
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Topic: 185
    Posted: 17 Feb 2026 at 5:41pm
Does anyone have a diagram that shows how a 185 diesel batteries are hooked up.
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 7:26pm
It’s 12v so positive to positive
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2026 at 9:10pm
12 Volt, Negative Ground system.
 Positive battery terminals to the front in the box, they hookup Pos to Pos on the Batt's and that cable then goes to large Terminal on the Starter Solenoid.
 Negative side usually has 2 cables; 1 from each Batt's Negative terminal to the 1/2" fender mount bolt in lower front of left fender.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:19am
My suggestion is to replace the two batteries with one (size) 4DLT battery. They are heavy to drop in, but I think the big single battery is way better that the 2-battery original equipment setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 6:42am
A better option would be a group 31. This has become the standard battery for many things, therefore it it lower priced than many other special sizes. Around here they are just =/- $100 at the national brad battery shops. Even the low grade ones will be 950 CCA which is plenty for a 301 diesel. The top end ones can be about 1200CCA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:55am
Right now it only has one battery, and when it is warm that one battery will start it,  I was just looking at returning it to the original configuration, the current battery is old and needs replacing.  thanks.
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:34am
Ive changed everything i could to 31 threaded post style. 2 31s will spin a 8070 just fine. The threaded post is so much easier and i only need to keep ine style battery
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
One instead of ine
1984 80780
1957 D14
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 47 minutes ago at 7:10am
Several times I had trouble starting the tractor only to find that the terminals were dirty on one battery and the tractor had been starting on only one for who knows how long. With one 4DLT, I feel the tractor always started better than using two batteries.
I think most tractor owners would agree that the battery is probably one of the most neglected parts on a tractor. We never seem to look at it until it gives a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 12 minutes ago at 7:45am
A note to all those whose tractor has a LUCAS starter on them.   There are times that a Lucas starter will only work at 50% cranking power. That is one of their (many) faults. You think it's batteries or cables and it's really the starter itself. It still works, but at a diminished cranking speed. You will get by in summer weather, but winter cold is a problem.
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 28 minutes ago at 9:29am
Yes...Exactly what we have done.  I actually got 11 years out (2) group 31's in my 210.  Rural King Brand!!
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 42 minutes ago at 2:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 37 minutes ago at 2:20pm
100% agree. Then take a short quarter inch bolt with a flat washer and push it through the braided ground strap next to the battery. Use this bolt then for all your grounding needs, GPS, spray monitor, planter monitor. If you need to disconnect your battery, all you have to do is unhook the lead ground wire, and your tractor should be cold.
Edited by Unit3 - 36 minutes ago at 2:21pm
