185 |
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2111 |
Topic: 185Posted: 17 Feb 2026 at 5:41pm |
Does anyone have a diagram that shows how a 185 diesel batteries are hooked up.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1109 |
Posted: 17 Feb 2026 at 7:26pm |
It’s 12v so positive to positive
KJCHRIS
Posted: 17 Feb 2026 at 9:10pm |
12 Volt, Negative Ground system.
Positive battery terminals to the front in the box, they hookup Pos to Pos on the Batt's and that cable then goes to large Terminal on the Starter Solenoid. Negative side usually has 2 cables; 1 from each Batt's Negative terminal to the 1/2" fender mount bolt in lower front of left fender.
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5162 |
Posted: 17 hours 44 minutes ago at 6:19am |
My suggestion is to replace the two batteries with one (size) 4DLT battery. They are heavy to drop in, but I think the big single battery is way better that the 2-battery original equipment setup.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5247 |
Posted: 17 hours 21 minutes ago at 6:42am |
A better option would be a group 31. This has become the standard battery for many things, therefore it it lower priced than many other special sizes. Around here they are just =/- $100 at the national brad battery shops. Even the low grade ones will be 950 CCA which is plenty for a 301 diesel. The top end ones can be about 1200CCA.
Trinity45
Posted: 16 hours 8 minutes ago at 7:55am |
Right now it only has one battery, and when it is warm that one battery will start it, I was just looking at returning it to the original configuration, the current battery is old and needs replacing. thanks.
8070nc
Joined: 21 Mar 2019 Location: North Carolina Points: 705 |
Posted: 14 hours 29 minutes ago at 9:34am |
Ive changed everything i could to 31 threaded post style. 2 31s will spin a 8070 just fine. The threaded post is so much easier and i only need to keep ine style battery
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
8070nc
One instead of ine
1984 80780
