185 woes for the Doctor and others |
captaindana
Joined: 14 Sep 2009 Location: Fort Plain, NY Points: 2573 |
Topic: 185 woes for the Doctor and othersPosted: 06 Jul 2017 at 7:12am |
We. Have discovered an issue with our new to us 185 while baling and while on hills and while slipping the hi lo feeding heavy windrows. First off going uphill under load baling or even just going uphill not baling just pulling there is a distinct loud chirping noise in the final drive axle or transmission . If we turn to the right under load it gets way worse and is scarey like really loud binding noises . While starting the tractor every time the pto will immediately fly up out of off to partway on, enough to run a baler if one would let out the clutch at that moment. This occurs on every start up. Also in heavy windrows while slipping the power director in low she will grab occasionally and will not release even after putting it in neutral and even after putting it into high range and back to neutral. This issue can only be terminated by foot clutching. While tractor is sitting idling if we lock pto off there is no chirping noise in the torque tube tranny area. If we position pto lever out of off the noise continues to chirp. While pulling the double rakes or Tedder or haybines there's no chirping or binding noises however the pto somehow always comes out of the off detent and is partially engaged. In summary ,a dead pull going uphill with or without pto engaged and turning right will makemasevere binding noise like snapping metal. We can live with the pto popping on issues but are afraid of the uphill turning right under load issues. This concern is for both mechanical and possibles loss of life on our hills. Help please! Dana
Blue Skies and Tail Winds
Dana |
Posted: 06 Jul 2017 at 7:37am |
PTO lever and possibly Power Director lever problems, I'd be checking for a stuck pressure regulator spool in the P.D. valve. A pressure check with a 500 psi gauge is in order. The noise problem is difficult without actually hearing the noise. Check both final drives for OIL and if that's OK, I'd remove the cover under the seat and visually inspect the brakes for a broken drum spring causing the drum to spread apart.
captaindana
Posted: 06 Jul 2017 at 5:03pm |
Hi and thank you for the reply Doc. I have the original Allis 180 and 185 Tractor Service Manual. I do not see info on checking the pressure reg spool in the pd. It sure could be in there but any more info on how to do this check will be greatly appreciated. As far as the noises and the brakes are concerned it is not the brakes I kmow all about those issues and although I have not replaced these brakes in this tractor I have in many others and can rule that out. I did go out and dead pull the XT hooked to the NH315 up my bad hills and it performed flawlessly. Of course the PTO was not under load while doing so. let me know how to check that press reg spool thanks sooo muchn. Dana and Ian
Dana |
Posted: 07 Jul 2017 at 7:22am |
Power Director valve is located under the sheet metal under the steering wheel on the lower right side. When I have an issue with one, I usually remove the sheet metal and carefully cut loose that lower right corner free, so it can be retained with one bolt and is then very accessible in the future. A pressure gauge of 400-500 psi should be used to know where you are at. Pulling out the spool requires removal of a hex cap (7/8" wrench?) and getting ahold of the spools inner bore and pulling it downward. It might come very easy and it might be STUCK. Don't lose the inner plunger on the opposite end of the spring and make sure it also is free to move.
captaindana
Posted: 08 Jul 2017 at 5:08am |
Ok wow holy moley thank you for all of your incredible knowledge I will report as I find out more answers. I am wondering do I plumb the gauge into the pd line and run it and report the pressures I see? Approximately what pressure should it be? At what engine rpm? Sorry for my uncertainty but I can find nothing in my service manual on this. Thank you.
Dana |
captaindana
Posted: 08 Jul 2017 at 5:47am |
My BAD! In my tech manual i was in thr remove and reinstall section. Now I have found the correct how to in the hydraulic section. Pilotmerror struck again 😫! Thanks! Dana
Dana |
Posted: 08 Jul 2017 at 7:44am |
Pressure ports on the manifold under the right platform...1/4" pipe thread. Pressures should be under 300 psi at half throttle or more.
captaindana
Posted: 08 Jul 2017 at 8:24am |
Doc I removed the 2 plugs 7/8 in wrench under pd valve and all seems well. The 2 ports under the right foot do i take pressures from forward, rearward one or both? Thanks
Dana |
captaindana
Posted: 08 Jul 2017 at 8:26am |
I also removed both 7/8 plugs under pto valve. Both had some metal filings in the plug cavity. Theres absolutely no leakage of oil anywhere around these valves.
Dana |
captaindana
Posted: 08 Jul 2017 at 12:38pm |
Ok pressures from under right foot : FRONT PORT high range 170 low range 260 psi
: REAR PORT. high range 260 psi and low range goes to 0 These readings remain the same whether pto is on or off |
Dana |
captaindana
Posted: 08 Jul 2017 at 2:40pm |
Also we plumbed gauge into both ports on pto valve. Pressures stay at 270 at all engine rpm settings while engaging and disengaging pto with the 10 psi flicker. The problem we see is at lower Rpm pulling pd from hi to low range will spike pressure to 350 and kick pto on if it's off. However with rpms over half throttle or more pulling hi to low on pd only shows the 10 psi flicker.
Dana |
waltw
Joined: 17 Sep 2009 Location: williston Fl Points: 45 |
Posted: 08 Jul 2017 at 3:42pm |
The clicking grinding sound could be loose lug bolts holding wheel to hub. That happened on my dad's 185 we were cultivating it would sound pretty bad turning around at end of row.
That want solve your pto/power director problem. I could see the back and forth motion of a square baler plunger causing a loose wheel to click like that. |
Posted: 08 Jul 2017 at 3:45pm |
The 260 psi sounds about right for each range of the P.D. clutch. I'd expect near zero on the range that is not applied. Clearly the 350 psi spike is causing your PTO lever detent to let go. Is the detent worn or weak?? Is that pressure spike normal or not?? I'd have to compare to another tractor to answer that. One 7/8" plug is for the low/neutral/high spool. The other one is for the pressure regulator spool. Should be a spring, some shims, a spool and a floating slug in the end of the spool. Did you remove all of this?? and is everything free?? Like I say that not zero number on the PD clutch bothers me.
ksbowman
Joined: 19 Mar 2013 Location: Paola, Ks Points: 228 |
Posted: 08 Jul 2017 at 5:30pm |
On my 170 I had a big clack from the right rear wheel when moving big bales. It was the lock on the spin out wheels not holding and it would slip about a half inch. the locks were tight so I put a spacer in to fill the void and that shut it up.
captaindana
Posted: 08 Jul 2017 at 5:54pm |
Ok y'all thanks for everything. I did not like that 350 psi spike so I took that regulator apart again, this time i dug with a fine little screwdriver under the spring and low and behold there was a 1/4 inch nut used for a shim. Since the pressures were nearly right on except for the spike to 350, I threw out that nut and put in 2 washer shims so now I have 270 psi pressures and when i pull back from hi to lo it spikes to just under 300 so my pto lever wiggles but does not fly out of off. I do not know if this is acceptable or not. Since my pto valve only spikes 10 psi while engaguing and disengauging and neutral to high on pd spikes 10 psi also but when I pull pd back to low it spikes more than the others maybe there is something amiss inside the low range valve.jThanks, Dana
Dana |
captaindana
Posted: 09 Jul 2017 at 5:54am |
Yes the pressure regulator valve slug spring work like new, flipping the slug up and down with my fingertip effortlessly. I am happy to have the pressures where they are , I am like you say Doc not sure of that spike is normal or not without trying the gauge on other tractors. There is still a clang in the torque tube when pulling from hi to low pd, not half as loud as when slamming from lo to hi while setting still in neutral at over half throttle. I had a brand new 180 in '73 and put 6000 hours on it but I really can't remember if she made such torque tube noises like this or not. And now since I lowered the pressures slightly and the high to low spike is under 300 psi instead of 350 the clang is quieter. Thanks for the help guys and now I am into the brake on the left side trying to get through first cutting before I do a complete brake job. As always buying a new to me tractor and bringing it up to par the way I want it is painful the first year!
Dana |
captaindana
Posted: 09 Jul 2017 at 5:59am |
Yes Doc the detents are solid and since I lowered the pressures it does not pop the pto out of off anymore. Id like to see inside of that pd how that works some day!
Dana |
