185 voltage regulator
Haymaker6060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Haymaker6060 Quote  Post ReplyReply Direct Link To This Post Topic: 185 voltage regulator
    Posted: 25 Feb 2025 at 7:06am
I have a 185 allis I just put a new wire harness in the old plug for voltage regulator was never plugged into anything. Does anyone happen to know where the regulator is supposed to be mounted and if it is needed. Picture would be great thanks in advanced
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 7:36am
does your tractor have an old generator... or a  newer alternator ?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 7:59am
It's under the black part of the hood for the steering column. Had trouble with mine some years back. I'll see if I can find a link to that thread.
Found it, may not be a big help though.
Edited by IBWD MIke - 25 Feb 2025 at 8:09am
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 8:11am
If some body put the new type alternator on you don't need the regulator
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 8:43am
should look like one of these... a generator uses the voltage regulator... and OLD ALTERNATOR can have a regulator also.. NEW alternators do not need a regulator, it is internal..... How was the tractor charging the battery before without the reg ?
generator
alternator
Edited by steve(ill) - 25 Feb 2025 at 8:46am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Haymaker6060 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 9:04am
Yes has an alternator
Post Options Post Options   Thanks (0) Thanks(0)   Quote Haymaker6060 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 9:07am
Not sure if that’s old style or new always charged fine before changing harness
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 9:22am
that looks like a Delco with a tack drive ?? If it charged before WITHOUT the regulator, then i would assume it has an INTERNAL regualtor... You can look at the TWO PIN CONNECTOR and see if they are parallel to each other or IN LINE with each other.. But since it WAS WORKING.. i think  you dont need the regulator wires,  but need to make sure the TWO PIN CONNECTOR is part of the NEW HARNESS.
check the two wires on the small plug on the alternator... something was rewired at that point for the alternator... you need that on your new harness.
Edited by steve(ill) - 25 Feb 2025 at 9:29am
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 2:48pm
generator
alternator
185s never had generators.  All were alternator with voltage regulator from the factory.  If it was charging before the wiring harness was changed, then one of the wires are not going where it is supposed to.  When I bought my 190XT, one of the wires intended for the alternator was actually hooked up to the water temperature sensor!  No wonder it didn't charge!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 4:04pm
he says it was charging with the old harness, and it was not connected to a voltage regulator ??  thats the confusing part... ( your right about the  generator.. my bad.)... possibly a NEW alternator has been installed with INTERNAL regulator  ?  and need to know if it is  a 1 wire or 3 wire... does the OLD harness and NEW harness have the same alternator  small wire plug ?
im thinking  there might be an EXTRA wire added to the OLD harness ( if they eliminated the voltage regulator)  that will be neede in the NEW harness  ?? .. if its a 3 wire....but the PAINT makes it look like original..
Edited by steve(ill) - 25 Feb 2025 at 4:33pm
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 25 Feb 2025 at 4:19pm
My 180 has an alternator and has an external voltage regulator under the sloped hood behind the instrument panel.
My 185 has no external voltage regulator.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 26 Feb 2025 at 10:26am
ALL 180/185 had the same wiring as to alternators. When the key is turned on one can hear a clunk and the right terminal gets 12V - the left terminal delcotron plug of the two is 12V. IF it was charging and the harness was not plugged into the alternator - We think that is what you meant - it means the alternator was a 'one wire' or a self exciting internal regulator - it has to be revv'd up to around 1500 rpm to 'kick in'.  As stated above the regulator is under the black cowl and mounted to the hood with a rubber isolator pad - it has to be grounded. The factory harness plugs into the regulator with a plastic regulator plug.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 12:16am
Haymaker 6060, your picture is a Delco 10DN alternator with mechanical tach drive they normally use external regulator. Originally the Voltage Reg was under the small cover in front of instruments & on hood. There are 2 regulators available for that harness; with ammeter or with idiot light. They do not interchange, wrong regulator and won't charge.
 IF memory is correct the Delco 10DN can be converted to 1 wire with an aftermarket regulator that plugs into the 2 wire plug on alternator & 1 or 2 other wires.
 IF yours was charging without the flat plug for regulator in use, it may have 1 of these mounted someplace.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Haymaker6060 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 3:31pm
Thanks for all the feedback guys. I’m very new with wiring so I changed the harness wire for wire with the old one. I’ve looked this thing over a hundred times for a regulator. Having the hood off I happened to go look at the hood and there it is mounted to the hood. I would assume it’s still in working order seeings how it was charging fine but connections look rusted I’ll clean and attach it up. Thanks again for the help hope some of you got a laugh!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2025 at 4:01pm
thank you for coming back with a summary.. Yes, we were confused with the "no regulator" part.... makes sense now.
