185 Starter question
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Topic: 185 Starter question
    Posted: 19 Mar 2023 at 8:46pm
Whats the reason the starter kicks out prematurely? Its a Lucas starter. It wont stay engaged long enough to start the engine when its cold. As soon as the engine pops just a little the starter kicks out. I had a DR off a gleaner m setting on the shelf so I put that on and that one will stay engaged until you let off the button. Just curious what would be the likely cause.
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2023 at 10:53pm
My experience with Lucas starters is the same as yours. Pops out the first pop of the engine.
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 8:20am
Starter drive needs replaced.
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 11:24am
Many consider Lucas electrical parts as poorly engineered from the beginning. The only Lucas starter I have is on a small Ford diesel from the 1960's on a New Holland swather. It gave a lot of trouble until I bought a rebuilt one to replace it. The rebuilt never gave any trouble for 20 years, but a very seasonal low use machine. I have moved on and the old diesel has sat 10 to 15 years.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 8:17pm
Because it is a Lucas!!!!!!!!                        MACK
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2023 at 10:20pm
Well, I know many people don't like the Lucas starter, but my 200 has one and next year, it will be 50 years old and has had one "rebuild". I will say it's the best starting diesel I've ever seen for that time period. Bought a new 185 in 1972 with a Delco starter that was a hard starting tractor from day one. Sold it in 1993. It went thru 2 starters in 21 years.
