185 serial #
Earl (Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earl (Pa) Quote  Post ReplyReply Direct Link To This Post Topic: 185 serial #
    Posted: 30 Jan 2011 at 7:23pm
Could someone please tell me where to find the serial number on a 185. I would appreciate any help. Thanks
MNfarmerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 7:33pm
On the right hand side there are two bolts that connect the frame to the clutch housing and it will be on the clutch housing between the two bolts.  Should be 185 XXXXX
Brandon
1974 185
1977 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote Earl (Pa) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 7:43pm
Thank you very much.
Hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 7:47pm
I thought the # was on the left side of the engine above the alternator? Thats where mine is. Is that the right serial number or is that the one for the engine?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 9:18pm
Hunter, you from Hilsboro ND, or somewhere else, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 4:50am
Hunter the one above the alternator is the engine serial number.  Some cab frames will cover the SN on the bell housing and some won't.  We had a 185 with a Hiniker cab that did that but my Cozy Cab doesn't cover it.  Also some loader mounts can cover it too.
Brandon
1974 185
1977 185
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:31am
That would be on the right side looking from the front -- left side as you sit in the seat. At least, that's where mine is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:42am
Engine SN is on the left of the engine as you sit in the seat, tractor SN is on the right.
Brandon
1974 185
1977 185
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:45am
...you can't chose for yourself which side is right or left. Cars to tractors its always "sitting in the seat" prespective
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:09pm
MNfarmerAc. we have one of those custom cabs or somthing like that does that cover the serial number.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:16pm
Depends on what kind of mounts the cab has.  If you stand looking at the tractor on the injector pump side you will see the frame running along the engine.  Follow that to the rear and you will see where it bolts to the clutch housing.  There are two bolts there and if you look on the clutch housing between the two bolts that's where the SN is.  If part of the cab frame is bolted there chances are you won't be able to see it.  If you could post a picture we could see for sure.
Brandon
1974 185
1977 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2011 at 8:46am
ok i will look but i cant put a picture of it on here but i have some on my facebook.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:46pm
darrel. i am from hillsboro ohio.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2011 at 8:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 4:50am
Brandon
1974 185
1977 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2011 at 1:43pm
oh i see now i thought it was on a plate like the engine cereal number was but its molded in. lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2011 at 10:40pm
ok i got it its a 1974
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 6:03am
Glad you found it!
Brandon
1974 185
1977 185
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunter Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2011 at 7:57pm
ya me too!!!!
