185 repair ?'s
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Topic: 185 repair ?'s
    Posted: 12 Mar 2012 at 9:53pm
Did you screw the settlement bowl assembly out of the fitting? Sounds like it is pluged above the shut off  in settlement bowl. Unless weight retainer has come apart in pump plugging the check valve in top of pump. Loosen timeing window until fuel runs out. If it runs ok then, pump needs repaired.   MACK
