185 Rear tires & Rims
Big Al 485 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Topic: 185 Rear tires & Rims
    Posted: 08 Feb 2011 at 1:45pm
Hello all,
has anyone ever installed a set of 18.4 x 34s on a 185 ?
Will the rims and centers from a 6080 work on a 185 ?
Thanks
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2011 at 3:10pm
Have seen 16.9 x 38 on 185's.  Yes, I believe the 6080 wheels should work.  Probably will need to put studs in the 185 axles because the 6080 centers are cast and quite thick.
Always wanted to try what you are doing.  Please post some pictures if you set one up that way.
The innovators offer what others will imitate.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 2:06pm
Never say 34`s on a 185, but I have a 185 high clearance with 38`s I`m going to part out if your interested, tires are shot, but wheels and centers are fine.
Pullin With AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 2:48pm
What do you want for the rims & centers ?  Will have to check to see just how much that raises the rear end as I will be getting into clearance issue's  ( canopy )  on my shop door.
I think I can still squeeze by with the 34's though.
Thanks
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 4:28pm
With taller rears, you should put taller knees on the front axle too, or taller tires to level it out some.
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 7:27am
I`ll take $600 and throw in the 20" fronts if you are interested
Pullin With AC
This page was generated in 0.122 seconds.
