185 power steering cylinder |
Allis_Cooper
Topic: 185 power steering cylinderPosted: 20 hours 10 minutes ago at 9:36am |
Anyone on here have any experience disassembling the power steering hydraulic cylinder on an AC 185? There does not appear to be a cap that screws off nor do I see any snap rings. Someone on this forum will know the secret, they always do. |
ac-mike
Posted: 19 hours 33 minutes ago at 10:13am |
Tap head back inside enough to remove snap ring then pull out
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Allis_Cooper
Posted: 16 hours 34 minutes ago at 1:12pm |
Worked like a charm! You guys always know the answer. The pressed in outer seal around the shaft was a bear to get out! Installing seal kit 70255712-5 from DJS Tractor.
Posted: 15 hours 36 minutes ago at 2:10pm |
Before installing piston back into the barrel, wrap the new teflon piston seal with two wraps of paper and place a radiator hose clamp around the teflon seal and compress it. I'd wait overnite if it was mine and remove the clamp, grease/oil lightly and stick it slowly into the barrel. If you don't do this, chances are pretty good you will cut the new piston seal.
Allis_Cooper
Posted: 12 hours 36 minutes ago at 5:10pm |
Thanks for the advice on that. When I took the piston off the tractor the spherical swivel joints on either end fell out in my hand and some of the joint housing cracked off. Unfortunately, the only replacement with the correct dimensions I've found so far are from A&W Tractor Part Number: 244019V $136 each!!
If anyone knows of another source please let me know. They seem to be .3/4" ID and 1 5/8" OD. |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8711 |
Posted: 10 hours 58 minutes ago at 6:48pm |
well....the right parts are always worth what they cost. Your experience may differ.
Alvin M
Posted: 17 minutes ago at 5:29am |
AGCO has 70244019v For 102.95
