185 power steering cylinder
Allis_Cooper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Topic: 185 power steering cylinder
    Posted: 8 hours 18 minutes ago at 9:36am
Anyone on here have any experience disassembling the power steering hydraulic cylinder on an AC 185? There does not appear to be a cap that screws off nor do I see any snap rings.
Wink Someone on this forum will know the secret, they always do.
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 41 minutes ago at 10:13am
Tap head back inside enough to remove snap ring then pull out
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 42 minutes ago at 1:12pm
Worked like a charm! You guys always know the answer.
The pressed in outer seal around the shaft was a bear to get out!
Installing seal kit  70255712-5 from DJS Tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 44 minutes ago at 2:10pm
Before installing piston back into the barrel, wrap the new teflon piston seal with two wraps of paper and place a radiator hose clamp around the teflon seal and compress it. I'd wait overnite if it was mine and remove the clamp, grease/oil lightly and stick it slowly into the barrel. If you don't do this, chances are pretty good you will cut the new piston seal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis_Cooper Quote  Post ReplyReply Direct Link To This Post Posted: 44 minutes ago at 5:10pm
Thanks for the advice on that.
When I took the piston off the tractor the spherical swivel joints on either end fell out in my hand and some of the joint housing cracked off. Unfortunately, the only replacement with the correct dimensions I've found so far are from A&W Tractor  Part Number: 244019V $136 each!!
If anyone knows of  another source please let me know. They seem to be .3/4" ID and 1 5/8" OD.
