185 injector pump
tri5ernie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tri5ernie Quote  Post ReplyReply Direct Link To This Post Topic: 185 injector pump
    Posted: 18 May 2010 at 5:09pm
Can anyone tell me how to remove the injector pump on my AC 185, I think it's time for a rebuild. The 2 bolts at the front of the pump, will it come out if I remove these along with the lines???
Any help will be greatly appreciated
Ernie
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 7:38pm
remove the inspection plate on the side of the injector pump and turn the engine over using a screwdriver on the bottom of the bell hsg.through the hole, turn the engine over till the 2 lines line up in the inspection hole. the pump can be removed. !!!!!!! do not allow the engine to be turned over cuz u will need to re-time the engine. my advice remove the battery cable from the battery.
