185 implements
Big Al 485 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Al 485 Quote  Post ReplyReply Direct Link To This Post Topic: 185 implements
    Posted: 09 Feb 2011 at 9:29am
Hello all,
I have a 185 ( Diesel ) and am wondering what implements it is rated for ?
 What size plow will it pull ?
 How big of a disk ?
And most of all, does it have the power to pull a New Holland  1411 discbine ?
Thanks.
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 9:34am
Well it should pull a 4-16 plow easy, and probably a 13 foot disc, and it should pull the 1411 discbine, at the farm I work at, we pull one with a 686 IH which is smaller than a 185, and doesn't have the PTO the 185 does either.
Sam T-Ga View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sam T-Ga Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 9:46am
I pull a Kuhn 303GT mower cond.[10 ft cut & frail cond] and a Claas 160 baler with mine.
klinemar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote klinemar Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2011 at 1:32pm
A 185 has a lot of torque for no bigger than they are.I have seen Farmers pull 5/16 plows in light ground.We always pulled 4/16 and a 14ft. disc.I have a JD 930 11ft.disc mower and the 185 runs it just fine.I mowed 10 acres of hay once in an hour.
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2011 at 7:32am
Our 185 pulls our 12 foot disc very well without the cultipacker, we have clay loam soils in our part of Maryland.  We have used it to pull our 1411 discbine many times.  It does a great job however I would stay off of hilly fields with it.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
MNfarmerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNfarmerAC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2011 at 6:23am
Klinemar,
What gear do you pull that 930 in?  I have a 926 that I pull in 3rd high.
Edited by MNfarmerAC - 13 Feb 2011 at 6:25am
Brandon
1974 185
1977 185
