185 Hydraulics Problem
Rf 185 CH Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rf 185 CH Ohio Quote  Post ReplyReply Direct Link To This Post Topic: 185 Hydraulics Problem
    Posted: 12 Apr 2021 at 6:46pm
I have a 185 Crop Hustler. It’s a great running tractor but it has developed a hydraulic issue. The steering, transmission, and 3pt lift have all stopped working. If I bleed the hydraulics, via the pump, it will sometimes work for a short period then it stops again.
We have been thinking it’s probably the pump or there is a clog somewhere in the system. Any recommendations or suggestions are much appreciated.
Secondly, if it is the pump, will the pump off of a 190xt (gas) fit on the 185?
Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 7:21pm
Where are you checking the hydraulic oil level at ?? No, a 190 pump will not work. Has to be a 180 or 185.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2021 at 9:24pm
x2 out of oil.            MACK
