185 Hyd oil woes
Gary(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Topic: 185 Hyd oil woes
    Posted: 23 Jul 2024 at 7:19pm
Split 185 because of oil transfer Hyd oil to rear end replaced seals on pto shaft Customer tried to drive home and filled trans again Can power director seals leak and get into rear end???
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2024 at 7:28pm
Yes, both shafts have seals that can allow oil to transfer. If it moves oil from hydraulics to transmission quickly (under 2 hours) when running the upper shaft is the likely cause. You should also replace the 3 metal seal rings while power director is off. Maybe consider taking its PD clutch apart for inspection while it's off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2024 at 7:39pm
It overfilled trans in about a couple of hours so I will split again and check out powerdirector clutch
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2024 at 5:09pm
Was the pto shaft seals replaced?
Redicous View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redicous Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2024 at 7:26pm
How do I bleed hydraulic system on a 5230
Edited by Redicous - 04 Aug 2024 at 11:26pm
This page was generated in 0.067 seconds.
