185 Fuel Issue
cguetter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cguetter Quote  Post ReplyReply Direct Link To This Post Topic: 185 Fuel Issue
    Posted: 11 hours 29 minutes ago at 5:33pm
I have a question. The other day i was digging with my 185 and about an hour and a half in it decided to lose RPMs and power to the point it could barely pull itself. Push the clutch in it regains the RPMs but if you let of the clutch it goes back to barely even pulling itself again, limped it home and let it sit till the next day ran fine for an hour or so again and did the same thing, came home and let sit for a couple hours and put it on the grain drill and it did the same thing after an hour in again. One time i got off and played with the fuel plunger and it seemed like it helped temporarily but i replaced that a couple years ago so dont know if thats the issue and need to replace or not also fuel filter is only 20 hrs old. Any thoughts on cause or fix ideas. Anything is helpful. Thank you
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 18 minutes ago at 5:44pm
Check the return fitting on top of pump, bet it's plugging up with broken down flex ring material. You can put an open fitting in the hose barb's place or you can knock the ball and spring out of the return fitting. I clean and reuse them when I rebuild those as that return fitting is now over $60, adds to an already expensive rebuild job.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 44 minutes ago at 6:18pm
Might have a plugged tank vent. See if you can get the fuel cap off when it does it. If it is pulling a vacuum take your air nozzle to the hole in the middle of the cap. Be aware that anything that is plugging it will come toward you.
Ted
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 10 hours 14 minutes ago at 6:48pm
I drilled out my plastic fuel cans and installed a bolt for a vent I could take out and a small piece of the yellow drilling got down into the elbow of the strainer and made it act that way. I found it by pulling out the plunger it sucked it right back in, knew that wasn't right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 49 minutes ago at 11:13pm
Loosen screws on timing window so it leaks fuel and see if the "fixes" it. Bet a dollar the flex ring is shot. Know what you're doing before just pulling pump. Others have learned the hard way when they pulled a pump without setting timing first.
