185 Diesel problems
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: 185 Diesel problems
    Posted: 13 Mar 2012 at 4:35am
My 180D was doing the same thing only it would surge to higher RPM once in a great while then die, Injection pump finally gave up internally.  Best bet, pull the pump now while it is still running and get rebuilt.   It is pretty easy to align the timing marks in the little side window of the pump by hand then remove it and then reinstall realigning the marks you would still be in time.
If it is gas, you probably have something closing off the fuel outlet in the tank like a piece of rust or plastic.
This page was generated in 0.207 seconds.
